Anyone know what goes on this fitting?
Old Apr 3, 2008 | 11:06 PM
rayjj's Avatar
rayjj
Default RE: Anyone know what goes on this fitting?
Well mine is a NY truck, and I think we pretty much have the 2nd most strict emissions outside of CA. There really were only 2 setups, CA and Federal emissions. Mine has the Federal setup.
Old Apr 7, 2008 | 10:28 AM
killerdoberman's Avatar
killerdoberman
ORIGINAL: rgouette
Please tell me this is why I'm getting P1494 & rough starting..?
Or at least what's supposed to go on this guy...
Thanks lads,
Rich
What engine is that?
I have a 5.2 and on the passenger side just below the PCV hose in to the thottle body is a open connection just like this. I put my finger on it while the engine is running, and it does have vacuum. I looked around for an hose to attacha dn I found nothing.
Any ideas?
Same as yours?
I will have to post a pic when I get home tonight.
Old Apr 7, 2008 | 10:58 AM
rgouette's Avatar
rgouette
this is a 2002 4.7
Old Apr 8, 2008 | 11:39 AM
killerdoberman
Here is '99 Durango 5.2.
What is this and why is it empty?
Old Apr 9, 2008 | 09:36 AM
psykotic4x4's Avatar
psykotic4x4
ok killer, my 98 durango just has that line plugged. but a neighbors 98 has a vaccume line running to the power brake booster. id just plug it if theres no line running to it.
Old Apr 9, 2008 | 11:36 AM
dwhisnant's Avatar
dwhisnant
Here's the pic from my 99 5.2. It's plugged. Might want to get a plug on it before it sucks in or decreases some other pressure.
[IMG]local://upfiles/87758/4FBF571432D44199A3952BDD71D7410C.jpg[/IMG]
Old Apr 15, 2008 | 03:14 PM
killerdoberman
Thanks. I plugged with a couple of layers of duct tape and string. That should hold it until I get a better plug.
And after a couple of days...my higher then normal idle RPMs is dowm to normal. From 1200 to 750-800 in park and 1100 to 600-800 in gear stopped.
Old Apr 15, 2008 | 06:48 PM
deerang's Avatar
deerang
hey killer, it looks like that used to be plugged, I can see a ring around the opening... Your plug prolly just dry rotted, or overheated and cracked off.. good to hear that plugging it has helped
