How much drop on your hitch?
Old Apr 9, 2008 | 12:11 AM
WestCoastKevin's Avatar
WestCoastKevin
Default How much drop on your hitch?
Hello there,
For those of you with tow packages, how much drop do you have in your hitch? 2.0", 3.0", 4.0"?
I am just wondering.
Best Regards,
Kevin
Old Apr 9, 2008 | 12:29 AM
deerang's Avatar
deerang
Default RE: How much drop on your hitch?
I could measure mine, but I don't know where to measure from?? from the top of the ball to the middle of the receiver??
Old Apr 9, 2008 | 07:43 AM
Duranged408's Avatar
Duranged408
Drop is measured from the top of the shank down. So pretty much you measure from the top of the pin ( Which inserts into your hitch) to where the ball mounts.
Old Apr 9, 2008 | 09:20 AM
psykotic4x4's Avatar
psykotic4x4
i have a 3" suspension lift on mine and a 2" drop reciever seems to do fine for me. could go lower but i opted to keep ground clearance. i get no binding or anything that i can tell while towing my little trailer around.
Old Apr 9, 2008 | 11:28 AM
WestCoastKevin
Thank you very much.
Kevin
Old Apr 9, 2008 | 02:37 PM
Brordo's Avatar
Brordo
I don't think the info given from each member would be of any value unless you happen to have the same trailer being pulled. For instance, I have a stock height 2002 SLT+ and due to the fact that my trailer sits higher I actually have to use a 1/2" rise to level everything out. Just my $0.02 worth.
Old Apr 9, 2008 | 04:14 PM
WestCoastKevin
I know brordo. But a quick parking lot survey (comparing my knee to hitches) and a walk through a trailer sales lot told me that a 2" or 3" drop is fine for most things I will be pulling.
Thanks for the reply,
Kevin
Old Apr 10, 2008 | 03:22 PM
gr8scott72's Avatar
gr8scott72
It will be different for each trailer and obviously different for each vehicle that has had the suspension modified.
Old Apr 11, 2008 | 06:41 PM
hydrashocker's Avatar
hydrashocker
A good 2" drop is good for all around.
Sure some are higher and some are lower. Bottom line the 2" is the best all around choice
