trans speed sensor
Old Apr 28, 2008 | 12:55 PM
trkjmpslm's Avatar
trkjmpslm
Default trans speed sensor
PO 736,731. Dealer says need Leak detection pump and trans speed sensor for 2000 4.7 mpi 4 wl drv. Durango. Any suggestions. Seems easy enough to do myself. Will I need to catch fluids? Any special trans fluid? Parts availability? Can I get pics and step by step proceedure? Thank you. K
Old May 3, 2008 | 10:57 AM
hydrashocker's Avatar
hydrashocker
Default RE: trans speed sensor
Trans speed sensor is located on the drivers side middle half way down on the trans. Not sure on the other.
Old May 3, 2008 | 01:47 PM
jeff66's Avatar
jeff66
Leak detection pump should be under the battery tray.
