P0505 idle sys. malfunction, any others w/ this problem?
Old May 19, 2008 | 10:46 PM
Wredheadgirl's Avatar
Wredheadgirl
Junior Member
Default P0505 idle sys. malfunction, any others w/ this problem?
I have a 99 dodge durango that just came up with this error code and was wondering if anyone else had a similar problem. Randomly the truck will not start without me giving it some gas for about 5-10 minutes, like it will just die every time I try and start it. At other times the idle is ridiculously high and sometimes doesn't feel like it wants to stop!! Hoping someone can give me an idea to what part might be needing replacement!? Thanks! Beth
Old May 20, 2008 | 12:19 PM
hydrashocker's Avatar
hydrashocker
Default RE: P0505 idle sys. malfunction, any others w/ this problem?
Well hello again Beth,
Sure I can help ya, The problem is the Idle Air Control Sensor. (IAC sesor)
Just grab one from the dealer or parts store and install.
On your engine it is located on the throttle Body.
