ABS/Brake - Code 65 Internal Relay
Old Jun 10, 2008 | 02:14 PM
macfwcc's Avatar
macfwcc
Default ABS/Brake - Code 65 Internal Relay
1998 Durango - Replaced rear ABS sensor, it was cracked. ABS and Brake light still come on after a few minutes of warmup. Now the Check Engine light comes on.
Diagnostic on ABS/Brake light and it came up Code 65 Internal Relay open. How does one fix this?
Old Jun 30, 2008 | 11:17 AM
oldschool5's Avatar
oldschool5
Default RE: ABS/Brake - Code 65 Internal Relay
CHANGED BOTH FRONT AND REAR SENSORS / NO CHANGE / HAD ABS CONTROLLER REBUILT TOOK CARE OF PROBLEM / GO TO ABSFIXER.COM FOR MORE INFO / CHECK ENGINE LIGHT ON MY DURANGO TURNED OUT TO BE A MAP SENSOR / T20 TORX-15 MINUTES-$80.00-EASY FIX
