Can this be done?
Old Jun 13, 2008 | 04:22 PM
xosirisx's Avatar
xosirisx
Default Can this be done?
Is it possible to swap a 46re transmission into a 99 Durnago 4wd with the 5.2? If so what needs to be done to make this work? Any help would be appreciated!!! Thanks!!
Mike
Old Jun 13, 2008 | 04:36 PM
hydrashocker's Avatar
hydrashocker
Default RE: Can this be done?
It's the same block so I would think so.
Computer flash I think would need to be completed. Other than that I think it will bolt up with some minor parts. What's wrong with the original?
[sm=feedback.gif]
Old Jun 14, 2008 | 01:00 PM
xosirisx's Avatar
xosirisx
After the transmission gets hot I lose first gear. Not sure exactly why but probably has something to do with the clutch pack. I know the torque converter would have to be replaced with the 46re one, but I'm not sure what else would need to happen to make this work if its even possible. Replace TCM with 46re one? Starter? Flex Plate? ECM flash/swap? HELP and THANKS!!
Old Jun 17, 2008 | 09:52 PM
xosirisx's Avatar
xosirisx
any ideas guys? I need to get this fixed and i can't seem to find a tranny locally.
Old Jun 20, 2008 | 07:35 PM
n8ech's Avatar
n8ech
XO:
I am surprised that our resident tranny guys have not weighed in more on this one already. A tranny guy I am not, so I will say do a search here and you should come up with some info. The 46re is beefier than the 44re, so quite a few folks have made the swap/upgrade knowing that their 5.2 will not harm the 46re since it is made to live behind the more powerful 5.9.
Don
Old Jun 21, 2008 | 09:41 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
yes it is possible, a bunch of guys in the 2nd gen dak forum have done it i think, and there is a guy over there that did the 3.9-5.9 swap and kept his 44 re trans, so they are compatible (same bolt pattern)
and i think some 5.2s even came w/ the 46re trans, not 100% on that, but i think
Old Jun 23, 2008 | 08:58 PM
xosirisx's Avatar
xosirisx
Thanks.. Thays one hurtle. Now I just need to know if anything needs to be changed/modified in order to make this work. Torque converter i know for sure, but would I need to change the TCm to one designed for a 46re? or are they the same?
