shocks
Old Jun 17, 2008 | 08:14 PM
ghoghunter's Avatar
ghoghunter
Default shocks
Any comments on after market shocks for 2002 durango?
Old Jun 18, 2008 | 11:20 AM
Mean Green's Avatar
Mean Green
Default RE: shocks
I went with bilsteins andd I love them. Much better handling than the stockers but definitely a stiffer ride.
Old Jun 20, 2008 | 08:07 PM
n8ech's Avatar
n8ech
Default RE: shocks
GH:
X2 on the Bilsteins. You can get them on Ebay for ~$260 shipped to your door, and they have a lifetime warranty. Good enough for the Dodge Ram SRT-10, and various Corvettes through the years. Good enough for our D's.
Don
Old Jun 21, 2008 | 04:26 PM
DDSXT's Avatar
DDSXT
Default RE: shocks
Do you all change out the shocks yourself? If so, how easy is it?
Old Jun 21, 2008 | 09:55 PM
DRO318's Avatar
DRO318
Default RE: shocks
Okay shocks are something you canchange with confedence. This is the way I changed mine. For the front.First I Jacked the D up.I used Jack stands to support it. Then I unbolted the two bottombolts and the shock extended. Then I unbolted the top bolt using a wrench and a vise grip. Depending on your shock you may need an alen wrench or two wrenches for the top of the shock. Then to install the new bilstienshock I bolted the top first. Then used a floor jack to lift the new shock up to the mounting holes and put the bolts through the holes and tightened them. The rear was the same process. Let us know how it goes.[sm=yeahsmile.gif]
Old Jun 21, 2008 | 10:02 PM
DRO318's Avatar
DRO318
Default RE: shocks
Is anyone using edelbrock shocks?
Old Apr 11, 2009 | 06:25 PM
Durangovaldeez's Avatar
Durangovaldeez
Default Rear shock bolts
I did the front today but am having problems with the rear. How the F do you get the top bolts off? Do you need to dissabmlet the sway bar?
Old Apr 11, 2009 | 07:29 PM
badseed's Avatar
badseed
I just put on bilsteins today, and didn't have any problems. Did you lower the spare tire?
Oh ya, you can get bilsteins for under 200.00 delivered!! check shockwarehouse.com, not sure how long the promo lasts though
Old Apr 12, 2009 | 12:29 AM
hydrashocker's Avatar
hydrashocker
Thumbs up
I am and I LOVE EM!!!!!!!
I run Edelbrock Performer IAS Shocks. They help in the corners as well as off road. The best multi shock you can own IMHO. My truck holds the corners like a damn porsche.
http://www.edelbrock.com/automotive_...erformer.shtml
1998-2003 Durango.
2wd front is front 33405** rear is 34405**
4X4 isfront is 3341 and the rear is 3441
Old Apr 12, 2009 | 12:50 AM
DRO318's Avatar
DRO318
Yeah hydra I was thinkin of making the switch from the bils to Edel but wanted more peoples opinions
