Problems with iradic idling on start up
Old Jun 27, 2008 | 12:22 PM
994x4durango's Avatar
994x4durango
Default Problems with iradic idling on start up
My 99 318 durango when it starts is idling iradically when i start it up and let it sit for a while i didnt do it until after i put my cold air intake on it so i think it could be a vacuum line or something but i am still not sure so thats why i am posting this, so if anyone can help me i would much appreciate it.
Old Jun 28, 2008 | 12:05 PM
master tech's Avatar
master tech
Site Moderator & Tech
Default RE: Problems with iradic idling on start up
Have you try taking the cold airintake off and pull the air cleaner box back on, then see if you have the same problem.
Old Jun 28, 2008 | 10:33 PM
hydrashocker's Avatar
hydrashocker
Sounds like a full tune up is in order first.
What spark plugs are you using?
The other problem could be the Air Charge Temp Sensor, or cleaning of the TB.
Old Jul 8, 2008 | 12:56 PM
994x4durango
I put a tune up kit on it already and I have cleaned my throttle body but could there be a leak in the intake because i pressure washed my engine one time and it would do the same thing. It also could be from high milage because i have almost 155,000 on it though. I might try putting the stock airbox back on it and see what happens. Also when the code the check engine throughs is for the pcv valve which i had changed also when it first popped up so if the airbox doesnt fix it i dont know what the hell I'm gonna do.
