02 sensors
i have a 99 d that keeps throwing up po132 and po138 i have replaced both sensors and checked all my connections at least three times. any ideas what it might be. also i have a vibration at about 35 but it goes away the faster or slower i go. could i have a tire out of balance?? any ideas would be very helpful, kinda stressin out about this. just bought it about 2 weeks ago. hopefully its not something that is very expensive.... Thanks
P0132 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)
P0138 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2)
There have been reports of lubricant leaking onto the conections of these causing failure.
it is a 318. would the exhaust be hotter than normal coming out of the tail pipe if it is not keeping any back pressure on the engine? i will take the d to our shop and have the tires balaced and rotated. thanks for the advice.
took it to get the tires balanced and found out i had a tire with a broken belt. put on all new tires and fixed the problem. still need to get the cat checked. i will check back when i get it checked. anymore ideas would be helpful. thanks
Trending Topics
I had the P138 code pop up and I waited a while to replace the sensor. I was just being lazy but I did have the code ran. Well after about 30 days I forgot the code and I went back up to autozone to get it, and to buy the sensor. When they ran the codes this time I had two codes, the P138 and a new P601.
The P601 says, ECM internal fault, probable causes...
1- SHORTED INPUT SENSOR
2- Shorted electrical circuit
3- Failed ECM
I replaced the sensor that went bad (P138) and then reset the PCM. After about 10 minuted the check engine light came back on so I ran up to Autozone. The P138 was gone but the P601 was still on. Now, 6 months later, the P601 is still on.... Thats where my problem has led me and I cant figure it out...
3- Failed ECM
