AC Compressor Cycling
Old Jul 23, 2008 | 07:09 PM
MJZach's Avatar
MJZach
Default AC Compressor Cycling
The AC compressor in my 99 Durango 5.2 is cycling on and off. It will run for 8 seconds then shut off for 4 seconds. The vents are blowing cold air but just not enough to cool down the interior because the compressor won't stay engaged. What could cause this problem.
Old Jul 24, 2008 | 11:22 PM
hydrashocker's Avatar
hydrashocker
Default RE: AC Compressor Cycling
low charge. Have you checked it?
Second, it does engage intermedeatly to lubricate the moving parts.
Old Jul 26, 2008 | 11:12 PM
vagueprophet's Avatar
vagueprophet
Junior Member
defidently low charge. My compressor was doing the same thing. One of the gaskets blew out and had to replace the thing. Was pretty easy to do. Get the R124a with the dye in it so you can check for leaks after you fill it.
