Air Intakes... Closed in or open?
Old Jul 24, 2008 | 03:56 PM
03DurangoR/T's Avatar
03DurangoR/T
Default Air Intakes... Closed in or open?
Whats the difference if the air filter is closed in or open?
Old Jul 24, 2008 | 07:57 PM
Duranged408's Avatar
Duranged408
Default RE: Air Intakes... Closed in or open?
Depends on the design, moslty enclosed air systems are made to lessen the debris etc on the air filter meaning less maintenance, they can also assist in sheilding the intake from heat and/or drawing air from a specific area for a colder charge. I chose an open air system to maximize the working space under the hood.
Old Jul 24, 2008 | 11:19 PM
hydrashocker's Avatar
hydrashocker
Heat causes ****y gas mileage, poor drivability, excessive ware, excessive dirt particals, and water vapor to freeze. Bottom line it is not advised! The better thing to do is pipe in cold air directly from the outside.
Old Jul 25, 2008 | 10:15 PM
03DurangoR/T
so air from directly outside. will that help fuel effiency as well as performance?
Old Jul 25, 2008 | 11:34 PM
hydrashocker
OH YA!
Do a Searchon Ram Air in the 1st generation Durango section.
