serious knock
Old Aug 2, 2008 | 07:15 PM
benb612's Avatar
benb612
Default serious knock
133 k on the motor and the pistons are knocking or valves never beat on it or pulled anything anyone else have this prob?
Old Aug 3, 2008 | 12:08 AM
hydrashocker's Avatar
hydrashocker
Default RE: serious knock
[sm=huh.gif][sm=WTFsgign.gif][sm=wtf.gif][sm=huh.gif]
ORIGINAL: benb612
I don't understand????? Year, Engine, Trany, and problem??????
Old Aug 8, 2008 | 04:39 PM
n8ech's Avatar
n8ech
Sounds to me like a 5.2 or 5.9 motor with the infamous belly pan gasket issue. We know that this causes pinging/knocking under load.
Ben:
Give us more info and an update if you want help.
Don
Old Aug 9, 2008 | 10:51 PM
benb612's Avatar
benb612
sorry about that it is a 2000 durango 5.9 r/t
sounds like the front drivers side when i listened to it with a screw driver
Old Aug 10, 2008 | 08:54 PM
n8ech's Avatar
n8ech
Ben:
Thanks for the additional info. Answering a querie like this usually requires quite abit of information.
When does the noise occur?? Is it all the time, or just at certain times. How long have you had it, and do you know any of its service history??
While we are at this, get a flashlight, remove the air hat on top of the throttle body and look down inside there. Do you see wetness or oil???
Don
Old Aug 15, 2008 | 12:05 AM
hydrashocker
Could just be crapy gas. The R/T uses premo gas only.
Old Aug 15, 2008 | 06:55 PM
n8ech's Avatar
n8ech
Hydra:
IIRC, only the 00 R/T required premium fuel. 01 and up could make use of it, but did not require it. At any rate the engine should not run that poorly on the lower grades. Under load is where you would see the difference.
Don
Old Aug 15, 2008 | 11:07 PM
hydrashocker
n8ech,
Dude it is a 00 R/T!
I have seen more problems with the tunes and fuel including just companies with the R/T.
Old Aug 16, 2008 | 08:47 PM
n8ech's Avatar
n8ech
Hydra:
Mea Culpa on it being a double ought R/T. Like yourself, I find that I reply to so many of these posts that I confuse one with the other sometimes!!!!!!
Don
Old Dec 13, 2008 | 12:57 PM
benb612's Avatar
benb612
Default knocking
it only knocks when the car is warmed up
