code p0138. O2 sensor.
Old Aug 6, 2008 | 11:53 PM
nessy's Avatar
nessy
Junior Member
Default code p0138. O2 sensor.
Which O2 sensor is this and the location. Want to replace as code is coming up, but not sure on the location. Code comes up as bank 1 sensor 2, o2 high voltage. Thanks
Old Aug 8, 2008 | 12:30 PM
vagueprophet's Avatar
vagueprophet
Junior Member
I believe its the pasenger side upstream
bank 1, sensor 1 is driver upstream
bank 1, sensor 2 is passenger ustream
bank 2, sensor 2 is the sensor before the cat
Old Aug 8, 2008 | 02:23 PM
nim81's Avatar
nim81
is that on the 318 or 360? or is there a difference? i only have o2 sensors before and after the cat.
Old Aug 8, 2008 | 10:39 PM
vagueprophet
Junior Member
from 1997-1999 all 360s 2wds have 4 oxygen sensors the rest have two. I forgot to add one up there. so it should be
bank 1 sensor 1 driver side upstream
bank 1 sensor 2 should be the passenger
bank 2 sensor 1 is pre cat
bank 2 sensor 2 os after the cat
Old Aug 13, 2008 | 02:51 PM
nessy's Avatar
nessy
Junior Member
So I went under vehicle to locate the O2 sensors. On my 2003 Durango R/T. I can only find 2. One before and one after the resonator/Cat. Am I only supposed to have 2, and the code will still be for sensor coming after???
Old Aug 14, 2008 | 10:36 AM
nim81's Avatar
nim81
it would be the sensor after the cat
