caliper bolt holes stripped?
Old Aug 14, 2008 | 05:32 PM
nim81's Avatar
nim81
Default caliper bolt holes stripped?
i finally found the right spindle for my truck and the top bolt hole for the caliper seems to be stripped out. any one know of an easy fix for this beside buying a new dam spindle? this is the third one.
also i have a passenger side spindle off a 2002 4x4 durango for sale
Old Aug 14, 2008 | 09:42 PM
n8ech's Avatar
n8ech
Nim:
Two options for you are:
I think Napa and maybe the dealer sells an oversized caliper bolt. The down side is they are pricey, I think in the 35-40 buck range.
The other idea is to Heli-coil it. I have done this myself on my 72 Camaro of years back, and the repair held up just fine. IIRC, you buy the kit which includes a drill, tap, and 5 or so inserts. You will need to take your old bolt with you to size up what size of inert you will need.
Don
Old Aug 14, 2008 | 11:45 PM
hydrashocker's Avatar
hydrashocker
Many people have installed thread repair.
Do a search and you will find it. Also there was a TSB on it. Search for it in the 1st geration Durango section. I believe I could have posted in the thread.
Old Aug 21, 2008 | 11:16 PM
IndyDurango's Avatar
IndyDurango
You can use the Napa bolt for that fix. Just be careful and go back in with it SLOWLY and STRAIGHT.
NAPA Part # BK 6751539 @ $20.99
http://www.napaonline.com/masterpage...rsized+-+Front
HTH,
IndyDurango
Old Sep 14, 2008 | 02:19 AM
01durangort's Avatar
01durangort
Default heli fix is the best
do the heli fix...it is easy, cheap and works...I have done both sides all four bolts
cheers
