Durango brake problem
Old Aug 16, 2008 | 03:49 PM
dmattinvt's Avatar
dmattinvt
Junior Member
Question Durango brake problem
When I first take off for work in the AM, one rear brake locks up when braking until I use the brakes a few times. After a few miles the front brakes start dragging and wheels get super hot and smoke. Gas mileage of course is terrible. Are new front calipers the answer?
Old Aug 16, 2008 | 05:12 PM
nim81's Avatar
nim81
sounds like you need a whole 4 wheel brake job. not hard if you know what you are doing, or take it to a brake shop and just have them do an inspection to see what the problem is , its hard to diagnose brakes without actually looking at them.
Old Aug 16, 2008 | 05:18 PM
MEINEKEMAN1's Avatar
MEINEKEMAN1
both the front and the rear start locking up? Sounds like you're having a hydraulic problem.Possible the Master going bad and not relieving pressure.Try opening a line at the master when it's locked and see it that free's it up.If not,go to each wheel and open the bleeders and see what happens and so on.
Good luck man.
Old Aug 18, 2008 | 08:53 PM
hydrashocker's Avatar
hydrashocker
Could also be the brake balancer located on the frame behind the wheel panel on the drivers side small access panel.
Old Aug 20, 2008 | 09:09 PM
MEINEKEMAN1
Any progress on this man?
Old Aug 21, 2008 | 11:32 PM
hydrashocker
I think we might have hit a dead thread???????
Old Aug 22, 2008 | 07:48 PM
MEINEKEMAN1
So it would seem.Hopefully he'll post up if he got it fixed.
