5.9 Rango Fuel
Old Aug 16, 2008 | 06:14 PM
11/24/07's Avatar
11/24/07
Default 5.9 Rango Fuel
is it required to use a higher octane fuel than regular unleaded in the 5.9 L Durango?
Old Aug 16, 2008 | 06:26 PM
Big Red Chicken R/T's Avatar
Big Red Chicken R/T
Junior Member
I don't know about the regular one but you're supposed to in the R/T model.
Old Aug 16, 2008 | 08:07 PM
n8ech's Avatar
n8ech
Only the 00 R/T model required premium for a whopping 5 hp gain. After that, 01-03 R/Ts were made to run on 87 or 89 IIRC.
Don
Old Aug 18, 2008 | 08:50 PM
hydrashocker's Avatar
hydrashocker
They need at least 87 octane. Except the R/T model with the at least 91 octane requirment.
Old Aug 19, 2008 | 02:02 PM
Kidd_Funkadelic's Avatar
Kidd_Funkadelic
My 2000 5.9L R/T says "Premium Only" inside the gas door. I asked the guy I bought it from about it and he says he never put anything but the cheap stuff in. I've done the same and never had an issue since I bought it last fall. I've never even heard a tick. Now, have I given up some power from this? Perhaps. But I'm OK w/ that. So, technically, yes you are supposed to use it. But if you don't nothing bad will happen... At least not from what I've seen.
Old Aug 21, 2008 | 08:28 AM
Chris_Gorham's Avatar
Chris_Gorham
9.9 chances out of 10 its your exhaust manifold blowing - ticking sound is exactely how it sounded when mine went....Chris
Old Aug 21, 2008 | 12:18 PM
CJYJ's Avatar
CJYJ
Default Cjyj
I have a 2001 R/T with 125,000 miles all run on 87 no problems
Old Aug 21, 2008 | 04:37 PM
gr8scott72's Avatar
gr8scott72
What????? He said he DOES NOT have a ticking sound.
Old Aug 21, 2008 | 11:24 PM
hydrashocker
Dude he isn't the only one.
Those labled with "Premium Only" should use it. 91 octane and up.
There could be some other issues going on without the use of it including engine ware or PCM tuning.
