DIY Turn Signal Switch Replacement
Old Aug 20, 2008 | 11:45 AM
Wredheadgirl's Avatar
Wredheadgirl
Junior Member
Default DIY Turn Signal Switch Replacement
Hi all! Does anyone know where I can find instructions/directions on replacing the Turn Signal Switch? I would prefer to do it myself and am hoping the process isn't too complicated for a virgin auto repair girl!!!! Thanks for your help!
-Beth
Old Aug 20, 2008 | 02:06 PM
jaysquared's Avatar
jaysquared
Dont know how to but did your turn signal and hazzard lights not working? Same thing just happened to me recently and was wondering how to get this fix...
Old Aug 21, 2008 | 05:26 PM
mlkmgr's Avatar
mlkmgr
your best bet to any DIY repairs would be to go get a Haynes or Chilton manual. i prefer the Haynes. comes in very handy and has step by step how to's along with many illustrations.
otherwise most steering columns have some screws to secure the plastic or some interlocking clips/tabs. determine which type and disassemble the column. usually the switches (turn signal) are simply screwed in with some type of torx screw(s).
if you cannot find a used signal switch locally, check out www.car-part.com
they can locate parts in your general area or nationally. good luck...
