How hard is it to replace the water pump on a '99 Autopartswarehouse Durango? tnx..need help..
______________
dodgies43137632
You have to drain first the radiator. Then remove the following components; the fan and shroud, the belts, the pulley, and hoses. Then remove the pump. Good luck.
