Will 35x12.5 tires fit my stock durango?
Old Jun 14, 2012 | 12:45 PM
  #51
jack buaer's Avatar
jack buaer
Originally Posted by lvphotos
Sorry Jack but mine is definitely not a mall cruiser. Agree video doesn't show how steep hills are in your video. Where were you? I did Apex around the area we shot BITD Vegas to Reno. Seen nose almost touch several times. Some drops just don't show on film. I have had more balljoint issues than axle. Still 35"s should have stronger stuff. Check www.reevesracingvideos.com for proof it not a mall rat. Been to a lot of races to shoot. I tend to use more throttle.
That was filmed between Washeo Lake and Carson City out in the Open Country. Some of the trail I actually had to shift in to 4 wheel low first gear and creep it. My next run is Loon Lake then Truckee , in July doing a Bear Valley Loop Trail. If I hit black diamonds its only BD1 or BD2 nothing over that. Washoe to Carson City is White diamond 2/3 and to Virgina City is White diamond 3 Blue 1 on some trails.
These next runs are going to be killer since I will have a spotter and someone filming outside the truck plus the dash cam. I will be making about a 30 to 45 minute Video next time.
Old Jun 14, 2012 | 06:52 PM
  #52
lvphotos's Avatar
lvphotos
Sweet. Wish I could Come and share duties. I run a cannon vixia 1080i and 2.1 surround...5.1 available Mic. And can follow. New job in IA soooo no play for wile. All for snow day.
Old Jun 15, 2012 | 11:23 AM
  #53
Mopar_By_Birth_Durango_By_Choice's Avatar
What is the biggest tire i can put on my durango without switching axles or balljoints ext? I'm going to be doing a 3 inch body lift
Old Jun 15, 2012 | 06:54 PM
  #54
lvphotos's Avatar
lvphotos
See my pictures in this thread. 33x10.5 will be best 12.5 rubs
Old Jun 17, 2012 | 09:27 AM
  #55
Thank you. Its nice to be able to get a reply so quickly.
Old Jun 18, 2012 | 01:08 PM
  #56
jack buaer's Avatar
jack buaer
Here is a link to my Durango with Lift and 33"s
https://dodgeforum.com/forum/1st-gen...urango-70.html
Also not I added helper leafs in rear and trimmed 2 inches from the Rear front wheel well aka body of the truck.
Old Sep 5, 2012 | 10:57 AM
  #57
D_Fr3sh's Avatar
D_Fr3sh
New Member
Default Tires
I have a 2003 durango sxt, will 32x11.5 inch tires fit on it at the stock height?
Old Sep 5, 2012 | 05:45 PM
  #58
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
4x4 or 2wd???!?!?
on a 4x4 they should on a 2wd not likely
Old Sep 6, 2012 | 01:35 PM
  #59
lvphotos's Avatar
lvphotos
Should. Check turn radius for frame and other contact. Might put a few cranks in bars. Also depends on rim offset. A good tire store will let you test fit tires. Remember some aggressive tires with sidebiters will make contact before ATS. Tires are not what they say. Its probably not a true 32.
Old Jun 8, 2013 | 08:28 PM
  #60
330devildog's Avatar
330devildog
Default 33's vs. 35's?
recently got the wife a new car and now have the durango to with as i please. i have been doing alot of serching and reading and so far even though it's older this thread is the most informative. my durango is a 2002 r/t. i understand they don't make a lift kit for this year so my best option is the 2" t/s lift and 3" body lift. some guys are fitting 35's but most are going with 33's. my stock rims are 17's and the tires are 275/65r17 so just a fraction bigger than 31/10.5's. so i think i can fit the 33's no problem with the 2"x3" lift but i'm really wanting to go with 35's. so over all they're just 4" taller and 1 3/4" wider, break that down from center it's 2" taller and 7/8" wider each side. i really don't want to trim fenders. reason i am asking this is it seems most of you had the 15" rims so i'm thinking your rims are probably more narrow also. i think mine stock 17's are 9.5" wide so my durango might be able to handle the bigger wider tires better. is this the case or is it just wishful thinking?
