Sidewinder Custom brakes done
Old Sep 12, 2008 | 09:39 AM
2K R/T's Avatar
2K R/T
Default Sidewinder Custom brakes done
I did get the brakes done,Some of you know I got some brakes from GS ....Total shet
I got some parts from Darren at www.sidewindercustoms.com to finish the install,Installed an a bit of driving to see how they work
The pedal is up higher,Stopping distance is shorter,Not a thing bad
RICK
Attached Thumbnails Sidewinder Custom brakes done-viper-brakes.jpg.jpg   Sidewinder Custom brakes done-img_2778.jpg
Old Sep 12, 2008 | 09:42 AM
DRO318's Avatar
DRO318
Dude how much for the brakes. Are they front and rear?
Old Sep 12, 2008 | 10:01 AM
2K R/T's Avatar
2K R/T
The wheels on,Rear
The wheels on,Side
Old Sep 12, 2008 | 10:10 AM
DRO318's Avatar
DRO318
yeah nice setup but how much did it cost you? did you get all the parts from the same place?
2K R/T's Avatar
2K R/T
They are different for what you want
Check out the website
I have the aftermarket rotor,Rebuilt the caliper's,Added better pad's,Powdercoated them as well,A little more cost you may not Want
You can get the Sidewinder Custom part's and get your own Rotor-Caliper's-SS lines
RICK
Old Sep 12, 2008 | 10:15 AM
DRO318's Avatar
DRO318
cool thanks. by the way are those tires 285/50/20's?
Old Sep 12, 2008 | 10:24 AM
2K R/T's Avatar
2K R/T
No problem,Check out some of the stuff he does
Tires are 295-45/20 front and rear
RICK
Old Sep 12, 2008 | 10:33 AM
DRO318's Avatar
DRO318
Yead man I always wanted to get brembo brakes but I never did because I couldn't find one that fit. As we all know the stock brakes on these durangos suck. I will upgrade in time. as far as the rear did you have to ta the rear end completely apart to install the brakes?
Old Sep 12, 2008 | 11:53 AM
2K R/T's Avatar
2K R/T
Not that hard,Was easier then the front
Remove cover,Remove one bolt that holds the pin and clips on end of axle shafts inside rear end,Remove axel shafts,Remove Junk Drum's backing plate,Put in axle,Install the rear bracket,Rotor,Caliper,SS line,Bleed ...Enjoy
RICK
Old Sep 12, 2008 | 10:29 PM
IndyDurango's Avatar
IndyDurango
Cool
I call foul. I think that all the photos are photoshopped and not real. 16 posts? This guy isn't for real.
IndyDurango
P.S. Going to the show in Danville next weekend?
