Help with alarm system
Old Sep 19, 2008 | 08:29 PM
nealeyandjon's Avatar
nealeyandjon
Default Help with alarm system
I have the factory alarm system and i locked and unlocke the door twice now the alarm is going off anythime i open the door( i do not have the factory key fob) bought the durango used) is there anything i can do other than disconnect the battery
Old Sep 20, 2008 | 11:27 AM
nealeyandjon
This will work on Durangos from 1998/1999 to diss arm your alarm
Normally, you would insert the key in
the drivers door, turn left, then right
to disarm and reset it. If yours is malfunctioning,
you can disable it for good by doing the following:
The FACTORY ALARM DISARM WIRE IS
lt. green/orange |-|, Located at a the
black plug in the drivers kick panel.
Once Located, splice into this wire with
a simular guage wire, and put it to
a solid chassis ground. This terminates
the alarm functions entirely.
If you want to use the alarm again all you do is remove the spliced wire
un hook your battery let it sit over night and hook it back up
Old Sep 22, 2008 | 09:24 AM
hydrashocker's Avatar
hydrashocker
I have never heard this before. Putting continuity to ground just sounds wrong.
Are you sure that this can disable alarm?
Search in this room about it. There is a write up on this to do it the right way.
Old Sep 23, 2008 | 11:12 PM
IndyDurango's Avatar
IndyDurango
This guy posted his own answer to his own question? That's odd.
Yes... er... no... DONT ground a power wire. NONO.
IndyD
Old Dec 29, 2008 | 11:50 PM
nealeyandjon
This does work i went to 3 alarm specialist and paid for them to trouble shoot it and towed my durango to all three they looked it up and i did it at home and it works. By the way it's not power wire but the main sensor wire. according to the specialist
Old Dec 30, 2008 | 12:15 AM
Mean Green's Avatar
Mean Green
If you are ever looking to use the alarm again you can go to your local Dodge dealer and buy a fob and get them to program it to your D.
