98 durango check engine light question
Old Sep 29, 2008 | 12:24 PM
raff1205's Avatar
raff1205
Default 98 durango check engine light question
I have a 98 Durango and this morning I saw that the check engine light flashed and the vehicle kinda sputtered a bit when I first took off. The light didnt stay on. It then seemed to cleared up with no more problems. It has been raining here for the last couple days and I havent driven it. Is is possible that moisture could have caused this????
Old Sep 29, 2008 | 02:56 PM
schusterjo's Avatar
schusterjo
Could be... Hard to say... Next time it does it head to Autozone and they will use a reader to pull the codes on your truck for free... Matter of fact I just did this today.. Transmission speed sensor $16.95 and my light is out...
Old Sep 30, 2008 | 10:23 AM
hydrashocker's Avatar
hydrashocker
The code should still be in the computer. Go to Auto Zone and have it read and tell us what it was.
In the 4.7L I have seen rain effect the Camshaft Sensor.
Please give us the motor size and the code when you get it?
Old Oct 1, 2008 | 11:57 PM
nim81's Avatar
nim81
my cel flashes sometimes when i really get on it rpms about 4000 +
never stores a code and sputters
Old Oct 2, 2008 | 09:15 AM
DRO318's Avatar
DRO318
Cool
how many miles do you have on the wires. also are they touchin the engine? I had that sputterin prob and it was the wires on the engine.
Old Oct 3, 2008 | 02:10 PM
hydrashocker
There are hard codes and soft ones. I've seen the soft ones disappear.
Old Oct 7, 2008 | 06:51 PM
nim81's Avatar
nim81
i have the wires all off the engine , today i went to get a pack of smokes and started it up and blam blam cel random misfire po302 = cylinder 2 misfire and cylinder 8 misfire.
restarted the truck and it ran fine , checked the codes when i got back and only one up was cylinder 2 misfire. checked the plug it wasnt bad wires are new plugs are champion truck plugs. rotor and dist. cap new. so i dunno wtf is wrong with this thing
anybody wanna buy it??
Old Oct 8, 2008 | 12:06 PM
DRO318's Avatar
DRO318
How many miles do you have on the wires? That could also be the prob. they do eventually give out, but not all at once. Try this the two cylinders that have the miss, switch the wires with another two that will fit the length.
P.S.> how much for the "D" ?
Old Oct 9, 2008 | 06:40 PM
hydrashocker
Could also be a fuel pump!
Old Oct 9, 2008 | 10:10 PM
DRO318's Avatar
DRO318
yeah it's possible
