Tire Pressure's
Old Dec 1, 2008 | 08:36 AM
  #61
DRO318's Avatar
DRO318
How was the traction on the last set of tires?
Old Dec 27, 2008 | 12:16 PM
  #62
Facory's Avatar
Facory
I keep my Michelins at 35 psi for normal driving. When towing I will increase the rear to 37 psi. Although the tire shop suggested i go to 40 psi in the rear, I don't do it. I have read that you should never inflate past the manufacturer's sidewall max pressure rating.
Old Jan 13, 2009 | 02:02 PM
  #63
kilii's Avatar
kilii
no offense but the reason why i am a fan of the latest gen durango is because dodge fixed all these problems. I saw a review on http://ww.topspeed.com and it kinda won me over with this SUV. Dodge did a fantastic job fixing all these details on the 1st generation.
Old Jan 16, 2009 | 07:43 PM
  #64
hydrashocker's Avatar
hydrashocker
Second generations have more engeneering behind them so of course.....
Even in the manufactured years from 1998 thur 2003 they did many changes but we like the tank look of the 1st geration better.
Old Jan 17, 2009 | 11:58 AM
  #65
Facory's Avatar
Facory
Michelin LTX M/S 265 70R 16. Second set on the Rango. It's really hard to wear these things out. Stability and traction on most any surface is unbeatable. Expensive? Ya. BUT, you get what you pay for. I guess right know they are going for about $165 - $185 each.
Old Jan 18, 2009 | 11:43 AM
  #66
DRO318's Avatar
DRO318
Sounds great
Old Jan 18, 2009 | 05:46 PM
  #67
hydrashocker
You are right Factory;
Never inflate past the manufacture specifications. If you need more pressure to inflate to then you need to buy the right load rating tire.
I run load range C on my BFG KO 31X10.5 LT15 which the load rating allows for 50 psi.
Old Feb 16, 2009 | 11:19 PM
  #68
fugums2's Avatar
fugums2
Default family road trip
I'm taking the family on a 2400 mile road trip to california from montana. Just bought new tires. They say max psi is 45 cold. What is the best psi for that many interstate miles. I running a 5.9. Any suggestions would be great.
Old Feb 17, 2009 | 08:37 AM
  #69
Facory's Avatar
Facory
A little confusing. 45 psi would indicate trailer tires, although most carry at least 50 psi. Then you mention the 5.9 which would be the Durango. I don't know of any tires for the D that would carrry 45 psi. In any case, I would run them at the max pressure as stated on the sidewall.
Old Feb 17, 2009 | 09:29 AM
  #70
fugums2's Avatar
fugums2
Thanks Facory. After reading your reply I double checked, and they acually call for 50 psi. They are "Wild Trac" all season tires, but I thought that was alot of pressure too.
