Autolite Copper plugs ok?
Old Aug 19, 2012 | 08:10 PM
  #81
Turgurlas's Avatar
Turgurlas
Yes I have the stock engine.
I also need to do the Plenum upgrade on it as well, even though I am not showing any signs of leaking.
I am definitely taking the advice of people who know their stuff.
So stock I will go.
Old Aug 20, 2012 | 05:57 PM
  #82
C0lt0n's Avatar
C0lt0n
So what exact plugs and model numbers to use for 5.9L? Thanks
Old Aug 20, 2012 | 10:30 PM
  #83
IndyDurango's Avatar
IndyDurango
If you are going the AL route, they are:
Autolite 3924 or the cooler 3923
HTH,
IndyDurango
Old Aug 29, 2012 | 10:37 AM
  #84
Miguelito1961's Avatar
Miguelito1961
Default Champion Plugs
I'm going with the stock champion plugs per hydrashocker recommendation.
Is there any concerns with changing the plugs while the engine is warm, not HOT. I've got 2 hours to kill at my sons soccer practice tonight, was going to change them out then. I'd let the engine cool for about 30 minutes and then do the change.
Old Aug 29, 2012 | 08:16 PM
  #85
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
the only concern about doing plugs on a warm or hot engine is burning yourself, if its cool enough to touch go to town, just be careful not to overtighten bc as everything cools off more everything will contract some causing tightening
Old Aug 29, 2012 | 09:16 PM
  #86
Miguelito1961
Will do, thanks!
Old Aug 29, 2012 | 09:39 PM
  #87
jim1999's Avatar
jim1999
yep, just go with the copper ones
