Brake system re-work, no fluid to RR??
Old Oct 19, 2008 | 07:23 PM
datacop's Avatar
datacop
Default Brake system re-work, no fluid to RR??
All,
In my 2000 Durango, I've just finished some brake work that included the following:
2 new Roters & Pads for front
2 new drums for rear
2 new sets of shoes for rear
2 new wheel cylinders for rear
new spring kit for rear's
when I did the r&r for the RR wheel cylinder, I noticed that the cylinder was very dry. When I broke the line on the right side, no fluid drained out. I didn't think that much about it because when I did the left side first, I used my vacuum pump to pull the fluid from the lines.
However, after I got everything together and buttoned up, I'm unable to pull any fluid to the RR side. I was able to successfully bleed the LR, RF, and LF sides with no problem, and my pedal is now *VERY* solid.
So my question is, what could be keeping the fluid from the RR side? is there some proportioning valve that may be stuck? A distribution block somewhere that I'm not seeing? do I need to take it to (gasp!) my stealership to have them put it on a rack and look at it?
Any help or guidance would be greatly appreciated.
Old Oct 19, 2008 | 07:27 PM
andyg's Avatar
andyg
I would get under there and check the break lines going to the rear. One might have somehow gotten pinched shut.
Old Oct 19, 2008 | 07:58 PM
datacop's Avatar
datacop
In as near as I can tell, there are no kinks in the lines...
Old Oct 19, 2008 | 08:03 PM
andyg's Avatar
andyg
If that is the case if i were doing this, I would crack the line to the rear loose at the proportioning valve and see if you get fluid out of there. This is a very odd problem to happen.
Old Oct 19, 2008 | 08:33 PM
datacop's Avatar
datacop
You've got one on me....where should I look for the proportioning valve?
Old Oct 19, 2008 | 09:00 PM
andyg's Avatar
andyg
It would be near the front of the car probably mounted on the frame. They are usually within a few feet of brake line from the master cylinder. It will have a few lines going to and leaving it. find the line that goes to the rear and crack it loose and have someone push the brake pedal. Make sure you use a fitting wrench or else you will ruin the fittings.
Old Oct 19, 2008 | 10:03 PM
hydrashocker's Avatar
hydrashocker
Look in the wheel well on the drivers side front tire and there is an access panel to it.
Old Oct 20, 2008 | 11:52 PM
datacop's Avatar
datacop
Thanks for pointing to the location hydra.. I took a gander at it this afternoon and sure enough, there it was. I'll get it back up in the air this weekend and see if I'm getting any fluid from the proportioning valve.
