idle problem
Old Oct 28, 2008 | 02:53 PM
wifesd's Avatar
wifesd
Default idle problem
I hope someone can help me with this.
My wife owns a 2000 durango slt 5.9 litre engine.
When she goes to start it in the mornings it will start up but then die.she needs to keep her foot on the gas to keep it from dying.then it seems after it warms up it is ok and does not do it till the next morning does anyone know how to fix this problem???please help!!!!
Old Oct 28, 2008 | 04:23 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
take a look at the IAC motor ont he back of the throttle body(underneath the air hat) when my truck did the same thing(my old truck) its just a dirty IAC just clean it off and put it back in(or replace it if you want to ensure that its good) the first time you start it you WILL need to put the pedal down until the valve has a chance to find its home position then the 2nd time you start it will be fine hope you can understand if not post back and ill see if i can go into more detail
Old Oct 28, 2008 | 04:34 PM
wifesd's Avatar
wifesd
how do you clean it and the air hat that is the air filter housing right????
i dont know anything about this truck so a little more info would be appreciated thanx.
Old Oct 28, 2008 | 05:27 PM
hydrashocker's Avatar
hydrashocker
The air hat is the part that goes on the throttle body that provides the engine with air. It is large and has a 4 inch pipe that goes on the end of it that goes to the air filter box. There is 1 screw (wing nut) that holds it on. Remove the air hat and the sensor is located on the throttle body (like a carborator) on the side closest to the cab. Take it out and clean it with brake cleaner of carborator cleaner.
Also you might want to have the battery load tested to see if it is on the way out. Most auto parts stores have a machine that they can take out and test it in your vehical for free.
Old Oct 29, 2008 | 02:29 PM
Mean Green's Avatar
Mean Green
If that doesn't work out pull the plugs. it may just need a tune up.
Old Nov 1, 2008 | 04:34 PM
wifesd's Avatar
wifesd
well thanks alot you guys for all your input.
I did find out it was the iac valve. i appreciate this alot.
I just replaced it and all is weel with that part now i have to see about the brakes now.
