ahhhhhhhhh. what did i do?
Old Oct 30, 2008 | 01:22 PM
rebelboy's Avatar
rebelboy
Exclamation ahhhhhhhhh. what did i do?
wanted to replace heater core finally got it in and now i have no air and aloud hissing noise
i think i need to bring it to a dealer ship
Old Oct 30, 2008 | 02:44 PM
DRO318's Avatar
DRO318
Does the ac/ heat **** work?
check all the vacuum hoses one of the many may be disconnected
Old Oct 30, 2008 | 03:06 PM
rebelboy's Avatar
rebelboy
Default correct
black hose was disconnected now i have whistling noise coming from the "air box" is that normal ? seems like i wont hear it when the dash is back on checking hoses again any other ideas
Old Oct 30, 2008 | 03:43 PM
DRO318's Avatar
DRO318
Ok, thanks for responding.:cool
Now does the ac/heat **** work?
If so you should be ok. The air should work,but what I did when I had the same problem was turn the car on and disconnect a vac hose under the hood on to the firewall to the right of the TB . Now the whistling noise you have can be either a crack in the box that the core is in or just the air flowing through the box.
AS long as thed vheat and ac works your good.
BTW is your heater core connected to the Ac?
Old Oct 30, 2008 | 04:33 PM
andyg's Avatar
andyg
I replaced mine like 2 weeks ago. When I put it back together it wounded like I had a hurricane moving through the car. I noticed that I did not seal up a crack that was along the blower motor housing part and it was sucking air really fast. I sealed it with epoxy and now it is fine.
If you took yours out better than me it might not be this problem. I broke my box in many places upon removal. I needed 2 tubes of epoxy to fix all my breaks and cracks. It was that bad haha.
Old Oct 30, 2008 | 06:22 PM
rebelboy's Avatar
rebelboy
ya every thing works now i have check engine light any ideas?
Old Oct 30, 2008 | 09:10 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
prob another vac leak somewhere since you seem to have had a problem with that
Old Oct 30, 2008 | 11:05 PM
rebelboy's Avatar
rebelboy
ooooops was evap hose
