Rubbing noise when turning sharp
Old May 11, 2009 | 07:35 PM
bcv021's Avatar
bcv021
Default fixed problem
I found out after looking at this closer that someone must have put the tie rods on the wrong sides as they are shaped to give clearance for the rims on a sharp turn.
Old May 11, 2009 | 08:13 PM
IndyDurango's Avatar
IndyDurango
Missed this thread the first time through. Been there, done that! There is a little scallop on each TRE that must be in the right place to clear the rim while turning. If not, it will grind away and sound horrible. Glad you found it. Sorry I missed it to send you down the right path sooner.
Didn't get your TREs installed at BigO Tires service center did you?
IndyDurango
