air cleaner?????
Old Nov 7, 2008 | 02:37 AM
v8streetracin's Avatar
v8streetracin
Default air cleaner?????
hey guys i havent really found anything on this. i want to put a round air cleaner on. i wanted to get some more room under the hood for a compressor i plan on putting in for an air system w/train horns. duel purpose air up tires and a nice F * button and since theres no room at all. i was thinking about taking out the stock type intake and replace it with a round style one. like the k&n Xtreme filter. i made a custom true cold air intake. the hvac 90 tucked between light and radiator. but since i wheel her from time to time im always worried about hydrolocking my brandy new engine. even tho i drilled holes in the bottom of the air box, still kinda freaks me out. my question is has anyone swaped to a round air filter? if so please post with pro's and con's. and the size filter you used. looks like a 8" would fit perfect 12" max width w/some playing with the top rad. hose. by like 4" tall max. guesstamit. trying to kill two birds with one stone. more room on pass. side engine compartment and no worries with water. thanks
Old Nov 7, 2008 | 07:46 AM
gr8scott72's Avatar
gr8scott72
Here's mine:
Old Nov 7, 2008 | 10:23 PM
hydrashocker's Avatar
hydrashocker
You forgot the size tho? Width and height?
Old Nov 7, 2008 | 10:27 PM
gr8scott72's Avatar
gr8scott72
I don't really remember. 12x3 maybe? Pretty sure it's 3 inch tall. Any taller and you have to modify how you are going to keep the lid closed on the filter as the stock stud will be too short.
Old Nov 8, 2008 | 01:36 AM
v8streetracin
thanks so you can fit a 12" cleaner no problem? any diff. from stock setup to the round in performance?
Old Nov 8, 2008 | 10:30 AM
gr8scott72's Avatar
gr8scott72
I haven't dynoed it or run it down the track so I can't tell you and anyone that says they can tell the difference in performance from a different intake by the seat of their pants is crazy.
Old Nov 8, 2008 | 03:27 PM
hydrashocker
I does look like 12X3 tho.
Can ya measure it?
Old Nov 10, 2008 | 07:08 AM
Duranged408's Avatar
Duranged408
Yepp, anything better than stock. There is still a debate on its location draw, stock-fender well pulls a colder charge, just a hat topper pulls engine heat. etc etc etc. But i still say its better than stock.. In the end a colder charge (cai) intake would be the best but its not like we are running fine tuned engine where as 6 degree's assists 29hp. I removed all my ac components/battery etc etc to run dual spectre's (just looks) cant run a K&N right due to a body lift
Old Nov 10, 2008 | 08:55 AM
gr8scott72's Avatar
gr8scott72
I think this would be the best setup:
http://www.ramairbox.com/models.html
Old Nov 10, 2008 | 09:15 PM
hydrashocker
Most of those setups look like they are ready for functional hood scoop induction or Supercharger.
