Power outlet
Old Nov 9, 2008 | 12:26 PM
Mean Green's Avatar
Mean Green
You don't have any power on both sides of the fuse? I'm not sure about where the power comes from without looking at a wiring diagram.
Old Nov 9, 2008 | 11:19 PM
sunnypadreguy's Avatar
sunnypadreguy
i have power goin out of the block on the engine comp. i checked the fuses behind the reg fuse panel i get power to 3 out of 4. but nothing to one of them, with the key in any position. and the only thing not workin in my truck is the 12 v power outlets. both the one next to ciggy lighther and the one on the rear
Old Nov 10, 2008 | 06:43 AM
Duranged408's Avatar
Duranged408
To my knowledge it was a 20amp fuse, i cant remember if it was underdash or the side dash compartment though. i'll look and shout out later.
Old Nov 11, 2008 | 03:36 PM
Mean Green's Avatar
Mean Green
Are you using a test light on both sides of the fuse or a fuse tester? I'm not quite understanding whether you are getting power to it at all or if there is power on one side but not the other. Pull the suspected fuse and visually inspect it.
Old Nov 12, 2008 | 12:10 AM
sunnypadreguy
test light and also tested the fuse outside the fuse holder, fuse is good. i checked the power distribution there is a 50 a fuse i got power on both sides. checked the fuse on the fuse holder block under the dash. there is no power at ither the input side or the output side of the fuse. is there another fuse between the distribution block or the inside fuse holder?
Old Nov 12, 2008 | 11:47 AM
Mean Green's Avatar
Mean Green
I just looked at a wiring diagram and it is just the two fuses you checked. I don't know or why it would fry anything but the fuse but you may want to start looking for a smoked wire/connector. Oh and check your grounds first I'm showing G207 is where it grounds that means it's in the cab on the drivers side. There should be a ground on the firewall behind the pedals and apparently one more behind the drivers side kick plate.
Old Nov 13, 2008 | 09:12 PM
sunnypadreguy
i dont think its a ground, i ran power from the 12v lead i got running to one of my amps, and the power outlet works, it even powers the one on the rear panel.
