Power outlet
Old Nov 8, 2008 | 04:31 AM
sunnypadreguy's Avatar
sunnypadreguy
Default Power outlet
hey guys i got another one. i blew the fuse on my lighter outlet it was due to the cig plug on a cell charger breakin and touchin both metal surfaces. ok i replaced the fuse and all worked well about a day or two later i noticed the 12v outlet was not power up my lil ones dvd player so i tryed the rear outlet. no luck checked all the possible fuses and wires i ended up tapin the 12v wire to the radio and putting in a 15 amp fuse just incase. i did try to check power as far back as i could on the power side of the outlet. nothing.
Old Nov 8, 2008 | 09:23 AM
Durango03's Avatar
Durango03
Did you happen to check the Fuse on the DVD player??
Old Nov 8, 2008 | 10:52 AM
Mean Green's Avatar
Mean Green
The fuse for the power outlets is different than the fuse for the lighter socket. I had mine blow as well and didn't bother with it until I did my heater core since my dash was already out. The fuse is on the opposite side of the fuse block under the dash. It is a real bear to get to just trying to reach in and grab it.
Old Nov 8, 2008 | 12:52 PM
sunnypadreguy
u mean like where the blinker flasher is? under the steering colum, just left of the colum. if it is its a bithc to get to it, u got to have girly hand to be able to fit up there.
Old Nov 8, 2008 | 01:01 PM
Mean Green's Avatar
Mean Green
That's the spot!
That's also where your wife/girlfriend comes into play.
Old Nov 8, 2008 | 03:39 PM
hydrashocker's Avatar
hydrashocker
^ LOL ^
I want pics!!!!!!!!
Old Nov 8, 2008 | 10:49 PM
sunnypadreguy
That's the spot!
funny thing is i do have a pic where i can "say" thts what shes doin.
Old Nov 9, 2008 | 07:08 AM
sunnypadreguy
do you remember which fuse it was, at the bottom of the block there are 4 fuses, 10 25 5 10 amps. there is power to all of them xept the ist 10 the one next to the 25. fuse is good changed it just in case no power still. any idea?
Old Nov 9, 2008 | 08:49 AM
Mean Green's Avatar
Mean Green
I can't remember which one it was. I think it was a 10 amp fuse.
Old Nov 9, 2008 | 12:20 PM
sunnypadreguy
al fuses have power xept one 10 a fuse,
power to that fuse comes in from the distribution block on the engine compartment right? checked it at teh dis block power on both sides of big 50 a fuse, any ideas?
