Transmission Oil Capacity
Old Nov 11, 2008 | 06:23 AM
wordsworth's Avatar
wordsworth
Default Transmission Oil Capacity
Gentlemen,
just quick question, I bought the transmission ATF+4 Oil (2 Gal.) and the filter and i want to change my Durango 5.9L 2003 SLT 4X4 transmission oil...the question is how much does it take?
some body told me 6 Letters.
pls advise.
thanks.
Old Nov 11, 2008 | 03:27 PM
hydrashocker's Avatar
hydrashocker
Should be 5 quarts.
Old Nov 11, 2008 | 03:44 PM
wordsworth's Avatar
wordsworth
Default thanks
thanks hydrashocker
5 quarts. that means around 5.5 liters which i have already added.
Regards,
Old Nov 11, 2008 | 05:54 PM
hydrashocker
No problem.
To check your fluid level;
To do this you must run the vehicle for at least 15 minutes, place the shifter in all area's one at a time for 5 seconds each from park all the way down to low 1, then all the way back up to park, 5 seconds in each gear then slowly return it to the neutral position, engage the parking brake, then check the fluid level while the D is running. You will need to wipe and check it a couple of times to get the actual level.
Old Nov 12, 2008 | 12:32 AM
wordsworth's Avatar
wordsworth
thanks for the info.
