Severe Cavitation Damage to Water Pump
Old 11-15-2008, 04:55 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
It might have happened due from the heat up which I've seen before and only running 50/50 could do it.
Old 11-16-2008, 02:05 PM
Chris_Gorham's Avatar
Chris_Gorham
Chris_Gorham is offline
Default Cavitation Damage Photo as Promised
what do you guys think of this...Chris
Attached Thumbnails Severe Cavitation Damage to Water Pump-30-03-08_2303.jpg
Old 11-16-2008, 02:55 PM
Mean Green's Avatar
Mean Green
Mean Green is offline
It's kind of blurry. I'm thinking the coolant may have been breaking down and when that happens it starts producing voltage. If you have any coolant left in there stick a voltmeter probe in there and see what you get. Once your cooling system turns into a "battery" it can start eating up components.
Old 11-16-2008, 04:14 PM
hydrashocker
It could be cavitation. This would do 2 things and would include impeller damage however. But consitering the damage is to the softer metal it might have gone there instead but I don't know why. Still not sure eather way.
If the bearing was ****y from the start everytime you stepped on the throttle would put different pressures on it causing the impeller to touch creating a spot for decomposition to begin. Crap floating around in the system and breaking off when exstream temps happen seem more likely. Durring this, cavitation is deninatly going to happen in my opinion because of differences in pressure and the added heat.
Check this out direct from Prestone®
Q. What is the best antifreeze/coolant concentration for a vehicle? Can I use 100% antifreeze?
A. We recommend that you use between a 50% and 70% concentration of antifreeze. At least 50% is necessary to give the adequate amount of corrosion protection, as well as freeze/boilover protection. However, we do not recommend more than 70% antifreeze. This would cause restriction of the heat transfer capabilities, corrosion protection, and freeze protection. The concentration of freeze/boilover protection of the antifreeze mixture can be checked using a Prestone® Antifreeze Coolant Tester.
I think you are not installing enough for the heat over there and you need to run more like 70% antifreeze and 30% distilled water. Remember to only use distilled water. I would still do that flush and refill with this. Cavitation can occur in this situation in my opinion.
Old 11-16-2008, 11:49 PM
Mean Green's Avatar
Mean Green
I doubt the blade is touching anything on the pump it would be worn smooth. I'm really thinking crap in the system or voltage.
Old 11-17-2008, 07:56 AM
Duranged408's Avatar
Duranged408
Duranged408 is offline
C'mon now.. Dont go giving those HHO guys any ideas on alternative power, be seeing a bunch of people with battery cables hooked up to the radiator and pump. Some with missing arms and fingers because the best time to hook up the cables is when the coolants viscosity conducts more energy when the engine is running
*** You could look into using HOAT aswell.
Old 11-17-2008, 10:38 AM
Mean Green's Avatar
Mean Green
Now that's funny.
Old 11-17-2008, 11:31 AM
Duranged408
Now that's funny.
The real funny part is im not kidding either haha
Old 11-17-2008, 10:03 PM
hydrashocker
^ Smart *** ^
Now this is not the HHO thread so back to the problem boys!
I would suggest that the impeller would smooth of the surface it hits but I'm only trying to find out what could have started this wear and consitering that the bearings have failed, maybe a possibility to start a decomposition trend.
Old 06-09-2009, 09:26 PM
hydrashocker
I know this is an old thread but I found this in the Service Manual:
COOLANT PERFORMANCE
ETHYLENE-GLYCOL MIXTURES
The required ethylene-glycol (antifreeze) and water
mixture depends upon the climate and vehicle operating
conditions. The recommended mixture of 50/50
ethylene-glycol and water will provide protection
against freezing to -37 deg. C (-35 deg. F). The antifreeze
concentration
must always be a minimum of
44 percent, year-round in all climates.
If percentage
is lower than 44 percent, engine parts may be
eroded by cavitation, and cooling system components <---------------- Check this out!
may be severely damaged by corrosion.
Maximum protection against freezing is provided
with a 68 percent antifreeze concentration, which
prevents freezing down to -67.7 deg. C (-90 deg. F). A
higher percentage will freeze at a warmer temperature.
Also, a higher percentage of antifreeze can
cause the engine to overheat because the specific
heat of antifreeze is lower than that of water.
100 Percent Ethylene-Glycol—Should Not Be Used in
Chrysler Vehicles
Use of 100 percent ethylene-glycol will cause formation
of additive deposits in the system, as the corrosion
inhibitive additives in ethylene-glycol require
the presence of water to dissolve. The deposits act as
insulation, causing temperatures to rise to as high as
149 deg. C (300) deg. F). This temperature is hot
enough to melt plastic and soften solder. The
increased temperature can result in engine detonation.
In addition, 100 percent ethylene-glycol freezes
at 22 deg. C (-8 deg. F ).
Quick Reply: Severe Cavitation Damage to Water Pump
