coolant capacity
Old Dec 13, 2008 | 01:15 PM
benb612's Avatar
benb612
Default coolant capacity
how many gallons does the 2000 durango hold? i am thinking 3.5 gallons is that right?
Old Dec 13, 2008 | 02:36 PM
Neo1130's Avatar
Neo1130
Which motor?
Old Dec 13, 2008 | 04:10 PM
benb612's Avatar
benb612
Default Coolant 5.9
2000 r/t 5.9
Old Dec 14, 2008 | 03:05 PM
Mean Green's Avatar
Mean Green
I think it's less than that. I believe I used 3 gallons gwhen I did my last flush.
Old Dec 14, 2008 | 08:51 PM
benb612's Avatar
benb612
ya it was about 3 flat thanks
Old Dec 15, 2008 | 12:20 AM
IndyDurango's Avatar
IndyDurango
dry block or refill on the radiator? Just get three gallons of 50/50 Prestone Premix and you'll be fine. Overflow takes less than 1, radiator right at 1 and the block holds the rest. Unless you have had the freeze plugs out, all you have is the overflow and the radiator to deal with for the most part.
BTW, the 5.9 will run exceptionally well and cool even very low on coolant... not that you would want to do that on purpose.
IndyDurango
Old Dec 15, 2008 | 12:22 PM
Mean Green's Avatar
Mean Green
It definitely has a decent cooling setup it just needs a larger radiator to do the job exceptionally well.
