2000 4.7 common o2 problem
Old Dec 16, 2008 | 10:44 AM
Mean Green's Avatar
Mean Green
We're always happy to help. Now go throttle someone to get some of your money back.
Old Mar 16, 2010 | 08:31 AM
esdaddy's Avatar
esdaddy
guys i have been fighting this same issue,, replaced 4 sensors, then on last one replaced the p/s powersteering,,, and ran brake cleaner all up and down the lines blowing it our with air nozzle and letting it also set over night, now same problem,, there are a lot of post out there on this, why isnt dodge trying to fix it?
Old Mar 16, 2010 | 09:28 AM
Dans01Durango's Avatar
Dans01Durango
It's not a safety issue like the ball joints. That's why.
Old Mar 16, 2010 | 10:32 PM
hydrashocker's Avatar
hydrashocker
They did on the newer models as far as I understand.
Old Aug 3, 2012 | 06:00 PM
Luv-n-my-Durango's Avatar
Luv-n-my-Durango
Talking My fix for this problem
Hi all. I realize this and old discussion but I thought I would share how I fixed this problem in my 2000 Durango so that maybe others won't spend $1500 trying to fix it...
First, I did A LOT of research and happened upon this forum which is where I got the idea to check my own vehicle. I was getting the p0171 and p0172 codes. Terrible gas mileage and black soot spewing from the tail pipe...
I also read of some people using a bypass wire to go straight from the O2 sensor to the PCM. I personally don't like doing that since the chance is there of blowing the PCM.
What I did was simple and pretty cheap.
MAKE SURE YOU GET AN O2 SENSOR REMOVAL TOOL!!! They make the job much easier since apparently Dodge wasn't thinking when they were drawing out where everything will go...
First I replaced the Power Steering Switch of course.
Next I replaced BOTH the up and down stream O2 sensors.
While they were apart I cleaned the harness connectors very well with some Brake Cleaner.
I then applied some liquid electric tape, use Starbrite brand if you can, others tend to harden to concrete over time, to the harness side of the connector to reduce wicking into the connector.
I then applied some Dielectric grease to the inside of the connector. Be sure not to use to much and disconnect and connect the connector a few times to make sure there is metal on metal contact or you may get false codes.
Next I cut a small drain hole into the harness jacket to allow any PS fluid to possibly drain before reaching the connector.
After reassembling and letting the old built up soot wear out I have had no more problems. I have put over 1000 miles on it with no Check Engine light. Gas mileage is back up and no more soot...
Total cost was about $250 and a couple hours of my time.
Hope this helps someone out there...
