Uneven front brake wear
Old Dec 24, 2008 | 01:00 PM
jlampitt's Avatar
jlampitt
Default Uneven front brake wear
I have an 01 Durango. This morning when getting the tires rotated I took the opportunity to check the front brakes and have noticed that on the drivers-side, the front pads are wearing unevenly.
Specifically, the inner pad has about 1/4 life left on it while the outer pad has a little more than half.
The passenger side pads seem to be wearing fairly evenly.
Any thoughts on issues I should check for, things I should watch for, etc? What might some causes be?
Old Dec 25, 2008 | 04:32 AM
Mean Green's Avatar
Mean Green
With the inner wearing faster than the outer I would look at replacing the caliper. It is an indication of the piston seizing up. Do it now or replace your rotors later and your caliper later.
Old Dec 28, 2008 | 07:59 PM
jlampitt's Avatar
jlampitt
Gotcha. Thanks for the input.
