Rim help
Old Jan 4, 2009 | 11:39 PM
DurangoDog1624's Avatar
DurangoDog1624
Default Rim help
I decided that im ganna get 33 x 12.5 x 15 tires. Im just not sure if i should 15 x 10 rims or 15 x 8. Which would be better or worse.
Old Jan 5, 2009 | 12:36 AM
deerang's Avatar
deerang
you should get 15 x 10.. Rule of thumb is to keep within 4 inches of tire width to section width.. It is possible to get the 12.5 inch tire on the 8 inch rim, however I believe the tire shop would recommend you going to a wider rim...
