ac help please
Old Jan 9, 2009 | 10:33 PM
rebelboy's Avatar
rebelboy
Default ac help please
ok i was having a problem with my defrost so i took the dash off and found the main/center blend door was sticking and not moving. so i fixed the problem and sealed the box with silicone . then i figured while i had the ac system dry i might as well replace the accumulator since it was only like 15 bucks . did that and waited for the silicone to dry. the next day i went out and put it all back together and it would not take any page oil and it only took 12 oz of r134 any ideas?
Old Jan 10, 2009 | 09:33 AM
Mean Green's Avatar
Mean Green
Did you get a vacuum pulled on the system?
Old Jan 10, 2009 | 11:10 AM
rebelboy's Avatar
rebelboy
sorry do you mean evacuate the system if so no the local shop wants 100 bucks to do this and i wanted to be sure it will fix the problem first
Old Jan 10, 2009 | 11:49 AM
Neo1130's Avatar
Neo1130
Yes, evacuate the system... You cannot just fill it after having it apart... Procedures man! They are made for a reason!
Old Jan 10, 2009 | 01:05 PM
Mean Green's Avatar
Mean Green
You have to pull the vacuum to boil any water out of there. Absolutely get this done and find a cheaper shop. I can get this done in my area for $60. That is before a buddy of mine bought a vacuum pump. Now I can get it done for free.
Old Jan 13, 2009 | 08:29 PM
rebelboy's Avatar
rebelboy
Default thanks
will have to find a cheaper shop definatly not the dealer they want 225 bucks i told them where to stick their machine
