imput speed sensor
Old Jan 12, 2009 | 08:16 PM
divedigger's Avatar
divedigger
Default imput speed sensor
I can't seem to locate the imput speed sensor on my 2000 Durango 4.7,could someone point me in the right direction?thank you
Old Jan 12, 2009 | 11:06 PM
Mean Green's Avatar
Mean Green
There's one on the rear diff and one that should be on the rear of the tranny.
Old Jan 12, 2009 | 11:27 PM
master tech's Avatar
master tech
Site Moderator & Tech
If you asking about the input sensor on the transmission. The 4.7 motor has the 45RFE or 545RFE, The input sensor would be on the front of the transmission near the torque converter. Just so you know the part number for the input sensor is the same as the output. They are interchangeable. But if you are asking about the ABS sensor, then that would be on the rear diff.
Old Jan 13, 2009 | 10:02 AM
divedigger's Avatar
divedigger
thanks for the direction.
Old Jan 13, 2009 | 11:34 AM
Mean Green's Avatar
Mean Green
Good to know tech I thought it would still be on the output.
