Headlights
Old Jan 20, 2009 | 09:24 PM
Kagedmaniak's Avatar
Kagedmaniak
Default Headlights
I cleaned my headlights today using wet, fine grit sandpaper + polish and they look pretty good, but while I was doing it I noticed that the headlight had tabs on each side - so it looked like the clear/front part "hooked" onto the back/black part. Is this just from installation or something or is it possible to remove it if you wanted to clean the inside?
Also for the light replacements, mine are pretty yellow/old , are silverstar ultras the best way to go replacement wise?
Thanks
Old Jan 20, 2009 | 09:56 PM
DRO318's Avatar
DRO318
I have silver stars their ok for every day use, in use for about a 8 months now
Old Jan 20, 2009 | 10:16 PM
Durango03's Avatar
Durango03
I had Silverstar Ultra's in my Avenger and I Loved them!
Old Jan 21, 2009 | 12:47 PM
Kensai's Avatar
Kensai
You will notice a big difference between the old yellow and silverstars. Also, Walmart also sells a headlight lense restorer for $20 a pack and they work really well on restoring your dulled headlight lenses. I applied this to my camry. It took off the yellow tarnish on my lenses almost instantly. It's been almost two years and my headlight lense on my camry still look relatively new and clear.
I attached a pic of what the package looks like from walmart.
