98 5.2 Alternator or Battery PLease Help
Old Jan 29, 2009 | 07:18 PM
greenpunishment's Avatar
greenpunishment
Unhappy 98 5.2 Alternator or Battery PLease Help
I touched the alternator while changing the plugs on the truck and it sparked. Do you think i may have killed the PCM because after a day later the volts meter goes down. I changed the alternator 3 times this week with Pep Boys crap still have no volts. And i used a a new yellow top just for fun
I do have a system remote start and big hella fogs all this stuff worked fine and HIDs for over a year and never did the lights dim .
Whats my next move?
Old Jan 29, 2009 | 07:30 PM
DRO318's Avatar
DRO318
See if you can get any codes
Old Jan 29, 2009 | 07:35 PM
greenpunishment
no scanner you think its possible
Old Jan 29, 2009 | 07:48 PM
Mean Green's Avatar
Mean Green
Does the truck run at all after this or is it just a charging issue?
If it just isn't charging ceck all of your connections and ohm test your wires to see if you burned any of them up.
Old Jan 29, 2009 | 11:34 PM
hydrashocker's Avatar
hydrashocker
Take it out and have it checked, or test the lead going into the fuse panel on the drivers side and ground to the battery with a multi meter. I run 14.2 thru 14.8 volts which is over the required 12.7 volts required to charge the battery.
Old Jan 30, 2009 | 07:56 PM
greenpunishment
140 amp fuse for 1 and I changed the terminal ends. I live to ride another day. I will post some pics of my D when i get a sec. Thank you all for your help. I will also try to be a post ***** in here as well
Old Jan 31, 2009 | 11:52 AM
Mean Green's Avatar
Mean Green
Well there you go.
Old Feb 1, 2009 | 04:25 PM
hydrashocker
Hope ya got it.
