A few different questions
2000 Durango, 125K. 4.7, all time 4X4.
1) The lights behind my rear defroster button and fog lamps doesn't work most of the time.
Does anyone have any suggestions on how to fix this?
2) I've had a problem with my windows sticking closed in the summer. I think I saw where I need to replace the motors. Is this correct?
3) Floor heat doesn't always blow. In fact, it's rare. It seems this is a very involved fix requiring the removal of the entire dash. Is this correct?
Thanks for any replies!
#1 Sounds like a loose connection.
#2 it's a possibility but they can be repaired if you so choose.
#3 It sounds like a vacuum issue. Pull the switchboard and see if there is any looseness or cracked vacuum lines. Also check out the vacuum line from the engine compartment. It goes through the firewall where the heater core sticks through.
