Temp Issue
Old Feb 13, 2009 | 04:33 PM
Duranged408's Avatar
Duranged408
Originally Posted by hydrashocker
I think you where dreaming last night?
Only dreams Indy has is nightmares, something about waking up and finding a 4.7 under his hood xD
Old Feb 13, 2009 | 05:32 PM
hydrashocker's Avatar
hydrashocker
^ lol ^
Old Feb 13, 2009 | 09:02 PM
IndyDurango's Avatar
IndyDurango
LOL! Nightmare indeed!
okay, weep holes... 4.7 stockers have a little drilled or manufactured hole in there. Most aftermarkets either don't have them, or have them in the wrong place. Few work well whereas a stocker 195 replacement is best for the 4.7. If you find you are overheating and have correctly burbed your 4.7 after a stat swap, it's a badly made stat. Unfortunately, I don't know which ones by brand name are good. Again, the best solution is the stocker.
IndyD
Old Feb 14, 2009 | 10:03 AM
Mean Green's Avatar
Mean Green
Jet makes a solid aftermarket t-stat.
Strap wrench FTW also. Just pull the belt and go to town. If you want more power now is the time to just put a E-Fan in there.
Old Feb 14, 2009 | 01:59 PM
hydrashocker
Indy,
Not to question, but installed in the wrong place?
The user installs it and I wonder if when installing it they should be placed in a special direction if the air hole is installed in the T-stat? I'm thinking there might be back flow if installed in the wrong direction. If installed right on a bend which is on all the motors a slight backflow could occur if the air hole is placed on the inside of the turn. Not dissin the stocker on this, just a question.
Just a thought.........
Old Feb 15, 2009 | 02:31 AM
IndyDurango
I don't think so. It is just a little weep hole and it shouldn't need orientation.
IndyD
Old Feb 15, 2009 | 05:34 PM
hydrashocker
Hmmmmmm!
Just a thought. Good to learn something new.
Old Feb 16, 2009 | 04:27 PM
tbasse01's Avatar
tbasse01
IndyD
all the aftermarket stats for the 4.7's have a weep hole
and it is for air bubbles to past so u know
if and only if you find one without the stupid little hole with the ball bearing in it, take out your drill and make one it is free
I have changed probably 100 4.7 stats over the years and they have always had the hole in them
even the cheapo ones for half the price
Old Feb 16, 2009 | 06:52 PM
hydrashocker
Drill a hole and that alows fluid to free flow. I don't like the idea so I just make sure they have them installd in the first place not to mention it one is drilling they can accidently bend the t-stat. If a bent one is installed then a proper seal might not happen resulting in bypass around the T-stat neck creating problems with erossion.
Just not a great idea in my book to drill em.
Old Feb 17, 2009 | 02:31 AM
wordsworth's Avatar
wordsworth
the e-fan might be faking not working..
so check it as it happened to me and the agency (united motors) said it could be the gasket and they asked me to open the engine and check that, i refused and i only found the problem in the e-fan which was not circulating but faking..
thanks.
