Turn signals
Old Feb 21, 2009 | 09:15 AM
stevec's Avatar
stevec
Default Turn signals
I have a 2000 Durango with 151000 miles I haven’t had it that long but I have had a lot of little problems like the ABS light problem I change the rear speed sensor and that fixed that problem. But now when I put on either my right or left turn signal both come and suggestions all lights seem fine.
Thanks
Old Feb 21, 2009 | 10:16 AM
hydrashocker's Avatar
hydrashocker
Sounds like a grounding problem.
Ensure that the battery cables are clean and the battery is good by having it load tested. Make sure the grounding connection between the chassis and the body is in good shape.
Now on the truck.....LOL....... You've bought a Durango with 151k miles on it and don't expect to put a little work in it???????.............LOL.......... You don't know all that has been done to it not to mention where is has been all it's life....... You can't just slam it dude!
Old Feb 21, 2009 | 10:40 AM
stevec's Avatar
stevec
Thanks for the reply….I’m not slamming it..It’s a great running truck… I actually didn’t buy it, I acquired it……long story. Besides the normal repairs for a truck this old and miles it’s be great.
Thanks
Old Feb 21, 2009 | 11:16 AM
Mean Green's Avatar
Mean Green
Check out my write up on electrical diagnosis and testing at the top of the section.
Old Feb 21, 2009 | 11:26 AM
stevec's Avatar
stevec
Thanks…I just read it very informative.
Old Feb 21, 2009 | 12:27 PM
Mean Green's Avatar
Mean Green
I'm thinking it could either be a ground issue or a short to voltage. If it is a ground issue you will have voltage left on the ground wire. This is not as likely as a short to voltage though. Work your way through the loom wiggling it as you go with the blinkers on and have someone watching the blinkersto let you know if one or the other goes out. If this doesn't work you will have to open the loom and follow it along in order to find the short. I personally would pick up a tone generator but they aren't cheap so for a single use it probably wouldn't be worth it for you unless you can return it when you are finished with it.
Old Feb 21, 2009 | 04:27 PM
stevec's Avatar
stevec
I do have a tone generator and it looks like I might have to use it. I can’t find anything buy looking and moving wires….
Thanks for your help
Old Feb 21, 2009 | 05:13 PM
Mean Green's Avatar
Mean Green
Oh ok well in that case just unhook the battery and go to town.
May I ask how you acquired the D?
