15 x 10 rims
Old Feb 22, 2009 | 10:59 AM
DurangoDog1624's Avatar
DurangoDog1624
Default 15 x 10 rims
I have a 99 durango, if i put 15 x 10 rims on my truck will i get any offset? If so how much? Thanks
Old Feb 22, 2009 | 04:12 PM
DRO318's Avatar
DRO318
I have one question, are you goin for the tires poked past the fender flare look or do you want them to be flush?
Old Feb 22, 2009 | 04:23 PM
hydrashocker's Avatar
hydrashocker
Depends on your rims. Personally, " IF " you do this the setback would have to be in the same place with the offset in the outer part of the rim. I'm sure that you couldn't have anymore in the inside because of rubbing issues and caliper setup.
Old Feb 22, 2009 | 07:47 PM
Duranged408's Avatar
Duranged408
These are 15x10 offset rango rims... Sporting 33"s 12.50 wide rubbers.... Yes the bolt pattern is unique 6x4.5.. Slim pickins..
3"body + t/s
