99 5.2 durango just quit running
Old Feb 26, 2009 | 06:17 PM
nealeyandjon's Avatar
nealeyandjon
Default 99 5.2 durango just quit running
I pulled a spark plug and looked for spark none, I pulled the coil wire to the distributor and looked for a spark none, i checked the hot wire going to the coil no power. does any one have any ideas to help
Old Feb 26, 2009 | 07:06 PM
hydrashocker's Avatar
hydrashocker
Check the fuses. Also the is a relay under the hood for shutdown.
Old Feb 26, 2009 | 07:36 PM
hydrashocker
Could also be a coil, or crankshaft position sensor located under the distibutor cap.
You can test these parts by buying a Chilton Manual at your local parts store and a multi-meter.
Old Feb 26, 2009 | 08:20 PM
nealeyandjon
thanks i'll look at the fuses and relays and check the coil
Old Mar 20, 2009 | 11:57 PM
nealeyandjon
Default HA Ha Ha
Well after replacing both the crank sensor and the cam sensor the engine still would not fire so i went back over the the entire ignition system from the cam sensro to the plugs the flint in the top of the distributor cap was completely missing and the rotor contact was bent a little so now i dont have to worry about the crank sensor or the cam sensor for awhile now went a head and did a full tune up plugs wires and oil change to include cap and rotor pcv valve and lucas fuel treatment on premium techron gas and she's getting 20mpg on the highway flat road at 75mph
Old Mar 21, 2009 | 12:00 AM
schusterjo's Avatar
schusterjo
Ah heck I was just about to say It is time to just get rid of it and donate it to me.
Old Mar 21, 2009 | 04:24 PM
hydrashocker
You said this:
After what was said it wouldn't be in the distributor cap......
Hard to nail that one down with miss information.
Old Mar 21, 2009 | 10:03 PM
DRO318's Avatar
DRO318
Hey did you just look or actually test with a volt meter?
Old Mar 21, 2009 | 10:15 PM
DragonOfMadness's Avatar
DragonOfMadness
I like to test for coil voltage like I test 9v batteries for the smoke alarms and hot looking female exotic dancers with body shots=with my tongue................
Old Mar 21, 2009 | 10:19 PM
DRO318's Avatar
DRO318
WOW, LOL dang man
