Missing engine
Old Mar 9, 2009 | 04:07 PM
Haplucki's Avatar
Haplucki
Default Missing engine
Need help my 2000 D 5.9l Has a horrific engine miss. This started about a week ago prior to tha it ran great. I have replaced the
plugs with champion OE. But it still misses. I notice it more when i give it gas and on the highway. This miss is also eating up my gas.. Any help would be appriciated.
Old Mar 9, 2009 | 04:55 PM
DragonOfMadness's Avatar
DragonOfMadness
Compression test the cylinderif it low= below 100,then do a leak down test= also check to make sure first that you actually have spark going to the cylinder=no spark pull the distibutor cap and check that and check the spark plug wire with an ohm meter for continuity.
Old Mar 9, 2009 | 05:40 PM
hydrashocker's Avatar
hydrashocker
Could be cap and rotor needs replaced. I like the Auto Zone brass connection upgrade for $2 more.
Also there is a TSB on plug wires that touch the engine and can burn through. Make sure you route the plug wires so they don't touch the motor or ground out. Check that wire thats missing. Also you can wait tell dark and get a spray bottle place it on fine mist and mist the wires and the bad one sould arch.
Get OEM wires if needed.
Champion plugs only and no platinum plugs.
No engine codes?????
Old Mar 9, 2009 | 07:37 PM
Haplucki's Avatar
Haplucki
Just replaced with champion plugs saturday. New cap and rotor bout 4 months ago. Did not check the wire though. One morning i had a hard time getting it started and it flooded out once it started it ran rough!!!!!
Old Mar 9, 2009 | 07:38 PM
Haplucki's Avatar
Haplucki
what is tsb??
Haplucki's Avatar
Haplucki
Oh no codes
Old Mar 9, 2009 | 08:22 PM
hydrashocker
( TSB ) Technical Service Bulletin
Still could be wires.
Old Mar 9, 2009 | 09:57 PM
IndyDurango's Avatar
IndyDurango
x2 could be wires. Easy fix and needs to be done every once in a while.
Using any oil?
IndyDurango
Old Mar 9, 2009 | 10:17 PM
redneckdodgeram's Avatar
redneckdodgeram
is it missing at an idle, or just when you step down on it, like its bout to die?
Old Mar 9, 2009 | 11:51 PM
DragonOfMadness
Flooded?How do you know it was flooded?If your wires checkout= compression test the bad cylinder=If you need to find the miss=remove each plug wire till you find lil or no change in the idle of the truck with that plug wire off.Then compression test that cylinder=below 100=valve hung up, burnt,pushrod bent,lifter bleeding out,rocker loose or toasted,or rings are gone.What is the mileage on the engine?
