7th Computer what to do???
Yank that msd garbage blaster out too and just get a stocker=for safety sake=with a stock engine ur not gonna need a millon mega joules to make it run good..We type english here damn I thought this was the Dutch Dodge Durango gen 1 forum>>Throws clogs in the trash can=lol
Hey Dark,you stated you had a msd blaster coil on your truck?=I can't find one for a durango,I did find a msd blaster coil for a 91-97 dakota and an accel yellow coil for a 99 durango=here are the specs the site listed for them notice they have different wind ratios and ohm specs and one is an e-core the other c-core style......You might have been sold the wrong coil for your truck.
MSD REPLACEMENT COIL, 2 PIN CONNECTOR, RED -- 3.962 in. Length x 1.757 in. Width x 2.968 in. Height, Male/HEI Wire Attachment Style, E-Core Style, Square, 1.2 Ohms Primary Resistance, Epoxy Internal Construction, 35,000 V Maximum Voltage, 70:1 Turns Ratio, 13.7 k Ohms Secondary Resistance, 8.0 mH Inductance.
ACCEL SUPER COIL, BLACK/YELLOW -- Male/HEI wire attachment style, C-core style, square, 1.0 Ohms primary resistance, 12.7 k Ohms secondary resistance, 42,000 volts maximum voltage, 76:1 turns ratio; Offers significant peak increases of 34 percent in energy, 17 percent in current, 23 percent in arc duration and 36 percent in dwell against OE.
I got these specs at link below look up 91-97 dak ign coil and 99 dur ign coil and the both look like they have the same connector.
http://www.autopartswarehouse.com
I've been running this for a long time.
MSD 8.5mm Wires #32189
MSD Blaster Coil #8228
Accel Distributor Cap #120329
Accel Distributor Rotor #130328
Accel OEM Adapter to Coil #140021AH
I had to use some Accel parts because MSD and Mallory don't make them yet.
Blaster II coil will roast you PCM.
