cylinder shut dow
Old Mar 15, 2009 | 10:52 PM
hydrashocker's Avatar
hydrashocker
Originally Posted by DragonOfMadness
Did you check the voltage at the tps=it should be about .06 volts and go to about 3.38 volts smoothly
Wrong:
TPS voltage should be between .4 to 4.5 volts to be in tolerance.
If you look in here there is a DIY for a modification for performance on the TPS.
Do It Yourself (top questions and answers)
The incomming voltage is 5.0 Volts but reduced to a maximum of 4.5
