Torsion lift how to... Cannot find one...
I got the rear shackles and will be installing them this week... At the same time, I want to do torsion lift... I don't need the new cam things, do I? I have heard I can just crawl under and start cranking, but I have no clue what way to turn or how much to turn?! I have searched google and other sites and haven't found any real info... No help?
Check the threads for tightening, i forgot which way it was. But you'd tighten each bolt 8 complete turns. Also for the rear shackles plan to take your hitch off (the hardest part) and dont forget to have the thickest washers avail handy.
** Try to get the front tires off the ground to unload the suspension, spraying the torsion bolts a day before hand insures easy turning with a big breaker bar.
They come out towards the center of the vehicle and on the driverside the offset hitch is right there..
Here's my nekkid rear again for reference..
408 needs to cover his **** end with one of those kenneshaw back bumper!
http://www.kenmtnac.com/WiDodDur9803.html
